No Connection
No Connection
Could One of you guys check my account please, unable to log into DSL account, not accepting username and password, bt account works fine, Have Posted a Ticket through Contact Us, But i'm sure these forums are browsed more often,
Please Assist.
Regards,
G.S
Account= gor3sci.plus.net
1 REPLY
RE: No Connection
I have just looked at your account and can confirm that all is functioning perfectly at this end. Furthermore, I have logged into your account using our external test machine and was able to browse with no difficulty.
I note you have altered your password following the raising of your ticket - can you confirm you are using the new and not the old password?
Please also ensure you are using the following format:
username@plus.net
If the problems continue, please re-raise your ticket.
Regards,
Mark.
| Mark Hague...................Unmetered & ADSL solutions
| Technical Support.......................for Home & Business
| PlusNet Technologies Ltd..........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----+
