No Access
Del
No Access
Smiley Hi Guy's,
Just tried to connect to INTERNET a few minutes ago and couldn't due to what looked like a router problem although I've not had any problems with my router since I got it ages ago so I switched-off for a couple of minutes then on again and problem solved.
Is or has there been a problem with PlusNets side of things?
Cheers.
Del
James
No Access
Yes.
One of our gateways got dropped earlier owing to a BT outage.
No Access
How long before its fixed?
I have been going around the houses trying to work out what was wrong here.
USing a dialup I checked in here and the USENET from the portal earlier but there was nothing to say there was a problem. So I thought it must be my fault
Why did someone not put up a warning here or usenet earlier?
Mand
No Access
As per the Service Status message here there was an issue with one of the gateways customers connect through. This meant that a number of customers were disconnected.
James
No Access
There's also a message on the phones.
Del
No Access
Smiley Thanks for the quick reply James it's nice to know it wasn't my router at fault.
Del
No Access
On the bright side I'm seeing some amazing speeds... I also notice from the packet dropping graphs that no silver is being dropped for a change. I guess some of us would like to see this "issue" not fixed ;-)
James
No Access
I imagine those on the other 3 gateways would appreciate it sooner rather than later Smiley
