Newsgroups
kenny
Newsgroups
I cannot seem to get into newsgroups like I could before (using Outlook Express) are you doing anything to it. Only just noticed it this week (since you have changed the system i.e. Introduction of idle timeouts)
I`ve not done/changed anything (well don`t think so?) I only use Outlook Express for newsgroups, my normal emailer is `thebat` which is all working all ok (same as normal web browser)
Can you shed any light anyone??!! :?:
1 REPLY
JonathanW
Newsgroups
Have you tried using the server text.usenet.force9.net? As this is the text only server that is more suited to accounts such as Home Surf and Plus.
