Newsdemon
topfisher
Newsdemon
I can't connect to the server on Newsdemon to download the newsgroups. Is it because I'm on BB+?
Plusnet Leader
Plusnet Leader
Newsdemon
You should be able to connect to the server and download the newsgroups. It will be slow on BB+ but still should work.
Can you raise a ticket through the help assistant with as much information regarding the issue as possible and we can have a look at this for you.
Is is a text or binary newsgroup? How far does the download get? Does it timeout or appear to be disconnected at a certain point?
topfisher
Newsdemon
Hiya, thanks very much for the reply. I've changed to another port on the newsreader and its working fine now.
Plusnet Staff
Plusnet Staff
Fixes: 159
Newsdemon
Good to hear, let us know if you have any more q's
 Chris Parr
 Plusnet Staff
