New PC only connecting at 736k old machine still conects at!
petsyb
could anyone tell me why this may be please
i have just built up a new PC for myself same as my old machine XP SP2 with all updates , same modem etc just dual core now
however when i connect to plus net it always has a download speed of 736kbps upload around 450 however if i reconnect my old PC it connects at 5mb :?
i know sometimes the line has to retrain but i thought that was just the line
I have tried reinstaling the sofwtare and checked the lines etc but all seems ok
Anyone ?
kreynolds
Have you checked the MTU and RWIN settings for the new machine?
James
Very odd!
Is it a USB modem or Router?
You haven't switched from Wired to Wireless at the same time have you?
petsyb
USB modem !
i thought it was very strange as well
everying is the same apart from new hdd,cpu,mem,and board
same setup, that is modem ,drivers & connection settings etc
any ideas anyone
Fixes: 8
Re: New PC only connecting at 736k old machine still conects
How was this measured?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Isitme
Just a thought, have you checked that you are connected to a USB2 port? If you are connected to a 1.1 port, this may account for the different speed. Try it in different ports and check your speed.
petsyb
well yep usb 2
though i have now reinstalled xp and the first thing i did before installing any other drivers was install my modem and i'm connecting at 5mb again Smiley
thx for the posts everyone
must have been some conflict along the way
