'Network host unreachable' routing problem
Hi, when running a tracert on steam9.steampowered.com (or steamx.steampowered.com) i get:
>tracert steam9.steampowered.com
Tracing route to steam9.steampowered.com [207.173.177.19]
over a maximum of 30 hops:
1 Destination host unreachable.
Trace complete.
and others on the steam forum don't seem to be reporting the same problem. Running a tracert from www.network-tools.com gives:
TraceRoute to 207.173.177.19 [steam9.steampowered.com]
Hop (ms) (ms) (ms) IP Address Host name
1 0 0 0 66.98.244.1 gphou-66-98-244-1.ev1.net
2 0 0 0 66.98.241.4 gphou-66-98-241-4.ev1.net
3 1 1 1 129.250.10.105 ge-0-1-0-50.r00.hstntx01.us.bb.verio.net
4 47 47 47 129.250.2.19 p16-0-3-1.r21.asbnva01.us.bb.verio.net
5 47 47 47 129.250.4.118 xe-0-2-0.r20.asbnva01.us.bb.verio.net
6 47 47 47 129.250.2.129 p16-3-0-0.r81.asbnva01.us.bb.verio.net
7 47 47 47 206.223.115.46 ashburn-ibx.eli.net
8 48 48 48 207.173.114.129 so-2-0-0--0.cr01.mcln.eli.net
9 52 52 52 207.173.114.250 so-0-0-0--0.cr02.chcg.eli.net
10 52 52 52 207.173.114.241 so-7-0-0--0.cr01.chcg.eli.net
11 61 61 61 207.173.115.234 so-0-0-0--0.cr02.mpls.eli.net
12 61 61 61 207.173.114.185 so-3-0-0--0.cr01.mpls.eli.net
13 93 93 93 207.173.115.165 so-0-0-0--0.cr02.tkwl.eli.net
14 94 94 94 207.173.115.90 p5-0-0.gw02.bllv.eli.net
15 94 94 94 207.173.69.238 gw-cust-valvesoftware-com.bllv.eli.net
16 Timed out Timed out Timed out -
so the problem may be a bit further afield. Any chance anyone could pin it down?
Ben_Brown
I get this from my home connection:
$ traceroute steam9.steampowered.com
traceroute to steam9.steampowered.com (207.173.177.19), 30 hops max, 40 byte packets
1 *censored* 0.652 ms 0.664 ms 0.657 ms
2 lo0-plusnet.pth-ag3.plus.net (195.166.128.64) 43.664 ms 27.344 ms 24.422 ms
3 ge0-0-0-403.pte-gw2.plus.net (84.92.4.2) 29.971 ms 27.403 ms 23.925 ms
4 195.50.117.169 (195.50.117.169) 28.084 ms 26.241 ms 25.250 ms
5 ae-0-54.bbr2.London1.Level3.net (212.187.131.146) 31.226 ms 26.163 ms 20.427 ms
6 as-3-0.bbr1.Washington1.Level3.net (64.159.3.254) 100.279 ms as-3-0.bbr2.Washington1.Level3.net (4.68.128.206) 98.615 ms 96.358 ms
7 4.68.121.144 (4.68.121.144) 99.915 ms ae-23-52.car3.Washington1.Level3.net (4.68.121.4Cool 99.031 ms ae-13-51.car3.Washington1.Level3.net (4.68.121.16) 98.073 ms
8 ge-2-2-0--101.er01.asbn.eli.net (207.173.144.29) 106.437 ms 101.526 ms 99.654 ms
9 so-2-0-0--0.cr01.mcln.eli.net (207.173.114.129) 102.973 ms 101.772 ms 99.948 ms
10 so-0-0-0--0.cr02.chcg.eli.net (207.173.114.250) 123.608 ms 118.566 ms 118.132 ms
11 so-7-0-0--0.cr01.chcg.eli.net (207.173.114.241) 122.497 ms 120.488 ms 119.867 ms
12 so-0-0-0--0.cr02.mpls.eli.net (207.173.115.234) 184.287 ms 126.344 ms 127.566 ms
13 so-3-0-0--0.cr01.mpls.eli.net (207.173.114.185) 134.018 ms 127.191 ms 126.885 ms
14 so-0-0-0--0.cr02.tkwl.eli.net (207.173.115.165) 185.357 ms 182.860 ms 181.485 ms
15 p5-0-0.gw02.bllv.eli.net (207.173.115.90) 189.225 ms 184.200 ms 181.795 ms
16 gw-cust-VALVESOFTWARE-COM.bllv.eli.net (207.173.69.23Cool 184.627 ms 379.656 ms 267.775 ms
17 * gw-cust-VALVESOFTWARE-COM.bllv.eli.net (207.173.69.23Cool 184.000 ms !X *
18 gw-cust-VALVESOFTWARE-COM.bllv.eli.net (207.173.69.23Cool 190.831 ms !X * 184.082 ms !X
As the first hop is not working for you then it is likely to be a firewall issue on your router. Please try disabling any firewalls you have and try again.
Re: 'Network host unreachable' routing problem
oops, i can't read. Shockedops:
there is a problem further afield as i can't access the ip address in question with either of my ISPs, but as bbrown says it looks like your problem is earlier in the route.
erm..it works on the computer downstairs. probably should have checked that before i posted hehe. it'll be a problem with my computer - i'll try and sort it out.
sorry to waste your time. i'll come awhinging later if i still can't fix it.
duh..it was peerguardian. sorry bout all that everyone. :s
