Netgear DG834PN and Interleaving
long-gone
I've googled and searched these forums (fori?) but can't find how to persuade my router to tell me if I'm interleaved.
Anyone know the magic commands, please?
timps
I have a netgear DG834G and it's as follows go to Run and type cmd then enter telnet 192.168.0.1 then enter cat proc/avalanche/avsar/modem/stats
You will then see your stats
it will show both fast path and interleaved, the one with figures showing against it is the active mode
Should be the same for your router i think
timps
long-gone
Thanks for your reply, but I've tried that and it doesn't work (file not found). I also tried the variation on Kitz site, but that didn't work either.
long-gone
Found it !!
The cat proc/avalanche/avsar/modem/stats above needs to be replaced with /usr/sbin/adslctl info --stats.
Apparently this also works with DG834GTs
PS you need to put you router int Debug mode first (http://192.168.0.1/setup.cgi?todo=debug)
