Nearly unusable throttled connection
I am a heavy user. I have been throttled. I am trying to migrate away but have problems with the ISP I am trying to migrate to but won't go into a discussion about that here.
My problem is that although I have been put on the throttled profile until I migrate out the connection is nearly unusable. I should be getting a little better than dialup speeds of 67kbps.
I am not.
I am getting a measly maximum of about 15kbps!
Now I have tried everything I can think of including playing with MTU, RWIN, MaxConnections and even pulling out an old Alcatel green ADSL USB modem to test the connection. No cigar.
I phoned a few times and raised a ticket about it. But PlusNET do not care. Their support staff do not know what the problem is and sympathise but those above them will not tell them why I am not even getting dialup speeds. All I get is that all I can expect is 'up to 67kbps' speeds. But honestly a max of 15kbps (It varies between 0 to 1.7 Kilobytes per second) is nearly impossible to use for web browsing. Pages are timing out it's so slow.
If this is how PlusNET treat their outgoing customers then I am glad I am leaving and will be asking others to leave too. I will talk my father around to leaving too just because of this.
I accept I broke PlusNET's rules (Which were late coming without a real warning and no VMU in place to even check my usage against during peak times I might add). But this seems unfair. As long as I have still paid I should still be entitled to get at least what they say I should be getting even on a throttled profile.
It's very sad how PlusNET are treating their customer base these days.
:roll:
what package are you on?
Exactly the same situation here. Unusable internet just after receiving email advising a restriction on speed had been applied to my connection.
Yes I broke the fair usage policy...
I have phoned 10 times over the past 3 days to get the restriction lifted but guess what... you can't have restriction lifted over the phone. You need to raise a ticket, but then if I can't even open the web page...
My speed has not been capped to 67KBps but to 1KBps.
Another unhappy customer on his way out
Tiscali sounds good, time to request MAC
Premier 2mbit
