MySQL
MySQL
I can't add to my database all I get is a:
"internal error has occured"
is this something I'm doing or is this a problem beyond my control
RE: MySQL
Please give exact details on what you did to generate this error. I will then look into it further for you. You may wish to rtaise this as a ticket via contact us.
Kind regards
| Kevin Revill ............... Unmetered & ADSL solutions
| Customer Support .................. for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
RE: MySQL
Exact details are:
Removed field "job_numbers";
Created new field "job_numbers"; (*see below)
type = "bigint";
Set Primary key to "yes";
Unique = "yes";
Auto Increment = "yes";
* I had to do it this way because I couldn't change tinyint to bigint (no error msg appeared for that it just didn't change)
hope that helps...
Will
RE: MySQL
Was this from a shell or script or using the MySQL admin panel?
RE: MySQL
this was using the mysql admin pannel (edit table link)
RE: MySQL
I will inform our developers who wil look into the issue further.
