MySQL Help needed
MySQL Help needed
Where can I find the answer to this puzzel?
Users can log-in to a page that only shows certain links depending on who that user is.
now I have got the login bit working but I can't think of a way to get a array inside MySQL which is what it would need, the way I see it...
a field with the link, job name and allowed users whould be needed:
Link Job Users
http:// 1234 user1, user2, user 5 user100
http:// 1235 user3, user4
etc etc etc
Any help would be great
Will
RE: MySQL Help needed
that table didn't really work... heres another attempt...
Link--------------Job----------------Users
http://----------1234----------user1, user2, user 5 user100
http://----------1235----------user3, user4
etc--------------etc--------------etc
Will
Good Afternoon,
We don't support MySQL coding. However I will look into this later on when it gets quieter and email you with what I've found.
My email address is dscotland@plus.net
Kind Regards
Duncan
| Duncan Scotland          Unmetered & ADSL solutions
| Senior Technical Consultant   for Home & Business
| PlusNet Technologies Ltd. @ http://www.plus.net
+ ------- My Referrals - It pays to recommend PlusNet ---------
Cheers Duncan,
if you could send anything you may find to william.blackburn@parkingroup.co.uk I would most appreciate it Smiley
I'll make sure Dunk has a look at this when he's next in.
Chris
| Chris Rugen ............................... Unmetered & ADSL solutions
| Senior Technical Consultant ................... for Home & Business
| PlusNet Technologies Ltd .......................... http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----------
tim_fenton
One suggestion I have is that it would be better to assign "roles" to the users so that you only have to specify which roles can see which links. That way you won't have a huge maintenance overhead specifying each user against a link...
For this type of thing I find a link table works well. If you have pages A, B & C and users a, b and c you can fill the link table with all the matches you want.
e.g.
Link.id, Page_id, User_id
1 1 1
2 1 2
3 1 3
4 2 2
5 3 3
This will give user a(id=1) access to page A(id=1), user b access to pages A & B and user c access to pages A & C.
Your select will then need to be something along the lines of select url from Page, User, Link where Page.id = Link.Page_id and User.id = Link.User_id
Hope this makes sense / works.
Paul Brooks
Oops - missed a bit in the where clause...
> Your select will then need to be something along the lines of select url from Page, User, Link where Page.id = Link.Page_id and User.id = Link.User_id and user.id = xxx
Paul Brooks
Paul Brooks
Thanks I think I understand where your comming from I will give it a go today if I find time, but I will keep you all posted thanks a lot guys!!!
Cheers
Will
