My referrals
My referrals
I'm using FP2000; and in 1 cell of a 2 column table on my sit'e links page I've pasted in the code you have kindly supplied. Unfortunately after this has happened, now twice, and I've checked the coding all I get is the coding!! Your assistance will be appreciated.Roll eyes
1 REPLY
RE: My referrals
This is a problem with FrontPage. I would recommend you use a text based editior or another web design package to input the code.
Chris
| Chris Rugen ............................... Unmetered & ADSL solutions
| Senior Technical Consultant ................... for Home & Business
| PlusNet Technologies Ltd .......................... http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----------
