My Questions Link
My Questions Link
Just noticed that the 'My Questions' link from the first page of the Member Centre has disappeared. (The one where you clicked 'View my Question' and it took you straight through). Is this intentional?
Plusnet Staff
Plusnet Staff
Fixes: 159
My Questions Link
I'm not sure where this link used to be, however if you click the help and support link you will see the option to view your questions then.
 Chris Parr
 Plusnet Staff
My Questions Link
Thanks for the reply. It used to be on the first page after login i.e. after the one 'If this page does not redirect you, click here..........'. I can access My Questions from Help Assistant but this link was quite useful.
Plusnet Staff
Plusnet Staff
My Questions Link
Was it somewhere around where the big banner is on this page?
http://portal.f9.net.uk/index_portal.html?home=membercentretop
In which case I wonder if it was removed to fit the banner in.
My Questions Link
I think that it has probably been removed to make way for the banner about the BBC Player. Maybe it will be put back sometime?
