More newsgroup woes
More newsgroup woes
i can't seem to connect to the usenet server - anyone else having probs with no connectivity?
a tracert to usenet.plus.net gets to gel-0-0-23.ptn-gw1.plus.net and then times out...!
More newsgroup woes
I assume this is working now? My traceroutes get through to 84.92.1.10 (nntp-readers.plus.net) without a problem.
More newsgroup woes
Everything is fine here, 500 headers downloaded in under 2 seconds, posts retreived instantly.
More newsgroup woes
not from here, still the same prob
can tracert everywhere else though...
maybe it's because i've requested my MAC?[/img]
More newsgroup woes
Tried rebooting your connection hardware and computer? I know it sounds cliché, but it fixes a lot of these sorts of problems (because you usually change gateway by rebooting).
More newsgroup woes
Nope it wouldn't be that. Have you been placed on a managed state? as part of the SUP? as this would affect newsgroups.
More newsgroup woes
was just kidding! seems to work ok now, ta! just needed to reboot the router, bit schoolboy, but i'm tired and a little bit tipsy...! :lol:
More newsgroup woes
[ i'm tired and a little bit tipsy...! :lol:
Know the feeling, glad you got it sorted Smiley
