Modems...
Modems...
Can anyone recommend a good modem? I'd like a V.92 to use with my Plusnet connection.
I cant seem to find any Modem review sites.
Thanks.
RE: Modems...
I have an Elsa USB Fun 56k modem which is V92 compatible. It was easy to install, however it is now retired in favour of my ADSL Fish. Do a search on Insight (www.insight.com/uk) or Action (www.action.com). Please be aware that V92 only workis with our 0845 numbers, and our 0808 unmetered Connect service is not V92 compatible.
Chris
| Chris Rugen ............................... Unmetered & ADSL solutions
| Senior Technical Consultant ................... for Home & Business
| PlusNet Technologies Ltd .......................... http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----------
RE: Modems...
Oh right, thanks for telling me. Any future plans to have the v.92 with the 0808 numbers?
Your DSL packages are very good, as soon as i can get it in my area i will most probably take out the service with you.
Thanks for the time and info,
Simon
RE: Modems...
Hi Simon,
That would be dependant on BT installing the v92 updates at the local exchanges. As yet they have not indicated any plans to do this.
Chris
RE: Modems...
Probably wont ever happen then. They're having a hard enough time DSLing the local exchanges.
Oh well.
RE: Modems...
> Oh well.
v.92 is a modem standard I thought I would see and use before upgrading to ADSL but you would have to agree that a new modem standard like v.92 from v.90 is too little too late with ADSL within reach.
RE: Modems...
Indeed, in much the same way that the 56k standard pushed the ISDN offerings into the shadows. Having said that, I STILL can't get ADSL so dial up is the only way forward (or backwards) for me!
Regards,
Mark.
| Mark Hague....................Unmetered & ADSL solutions
| Customer Support .......................for Home & Business
| PlusNet Technologies Ltd...........@ http://www.plus.net
+ ---- My Referrals - It pays to recommend PlusNet ----
RE: Modems...
If you want the "Rolls Royce" of modems then get a US Robotics, they simply are the best.
Regards,
Mark.
Regards,
Mark Henderson.
(thetop)
www.sussexbridalcars.co.uk
