Missing Tools??
Missing Tools??
I seem to recall PlusNet supplied a "useful downloads" section. It was a useful feature. I remember downloading a Linux OS called Phat. This feature seems to have disappeared or perhaps moved and I can't find it.
Anybody remember this? And if so, where did it go? Or is my memory failing me? It's been a while since I used the portal.
Missing Tools??
The feature you refer to is the "Batch FTP" tool, which is still available under Entertainment -> Tools of the portal menu.
Regards, Ian
Missing Tools??
Thanks for that, but it was a little different from the Batch FTP feature. It was more of a selection of useful applications and utilities, already researched by PlusNet. You did not have to find a program to download. It had already been selected by plusnet.
Anybody else have any recollection of this?
Missing Tools??
Yep, but think it went the way of the dodo along time ago.
Missing Tools??
Ah yes, I remember it now.. damn that was such a long time ago lol.
It's a fair challenge keeping up with how much plus has changed over the years...
Fixes: 8
Missing Tools??
I don't think it works.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Missing Tools??
Same subject:
What happened to this opt-in / opt-out automatic idle disconnection
I tried looking for it but cant seem to find it anymore.
glyndev
Missing Tools??
All the software that was available for download where very old versions and no one at +net had the time to set to and update it so it was decided to withdraw the facility.
