Maxdsl Yes or No
Captain_Digital
Maxdsl Yes or No
I have been offered a free upgrade to Maxdsl. Can anyone please advise as to what questions I should ask myself as the whether this is a good idea or not??
Line stats are as follows:-
Attenuation:
Local: 41 dB
Remote: 13.5 dB
Noise Margin:
Upstream: 25 dB
Downstream: 31 dB
Xmit Power Level: 11.33 dBm
ADSL 24hr Errors statistics displayed in 15 minutes interval:
Local RS Errors: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Local CRC Errors: 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 2 2 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 2 2 1 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 1 0 0 0 0 1 0 0 1 0 0 0 0 0 0 0 1 0 1 0 0 0 0 0 0 0 0 0 0
Local SEF Errors: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Local LOS Errors: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Remote RS Errors: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Remote CRC Errors: 0 2 0 0 0 0 0 0 0 0 0 0 2 0 0 0 0 0 3 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 0 0 0 0 0 0
Remote SEF Errors: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Remote LOS Errors: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
ATM Speed:
Downstream : 2272 Kb/sec or 5358 cells/sec
Upstream : 288 Kb/sec or 679 cells/sec
Downstream Maximum rate : 8192 Kb/sec
Upstream Maximum rate : 768 Kb/secc
Fast Mode
Thank you for any help
Liam
Maxdsl Yes or No
Looking at those line stats. I'd say you could most probably acheive a stable 8Mb line without any issues.
So, personally, I'd give it a go! :-)
(You can opt in at http://max.plus.net)
James
Maxdsl Yes or No
As Liam has mentioned, your line margins are fairly decent. Whilst I won't commit to 8mbps, because I think you might fall marginally short of those levels of synchronisation, it would definitely be worth the upgrade.
Feel free to give me a poke and I'll manually upgrade the connection for you.
Walrus
Maxdsl Yes or No
Consider the downside of max also - latency. This may not affect you if you're not a gamer. Interleaving present on MaxDSL lines causes large latency hikes, whereas this is unnoticable when surfing/email/downloading it is noticible with anything such as gaming mentioned above.
I issue this warning from experience, I used to have a stable 2MB connection with PlusNet and opted for MaxDSL. When I enquired to downgrade again, there was a £14.99 regrade fee (fair enough) BUT they could only offer 512K!
I'm not being negative, just balancing the +Max posts Wink
Plusnet Staff
Plusnet Staff
Maxdsl Yes or No
Interleaving can be switched off on a Max line, although if it's a long line that could end up causing more problems. The general trade off on Max is of higher sync speed and lower latency against stability.
shellsong
Maxdsl Yes or No
The attenuation is a bit tight but I reckon the noise margin figures are so good there shouldn't be any problems getting the full 8128 Kbps
Maxdsl Yes or No
They were going to charge you for a regrade back to a fixed 2meg service?
Thats wrong...they regraded me for free.
Maxdsl Yes or No
If you want better all round speed, it's also worth considering moving to an ISP that won't shape your traffic. What do you use your connection for?
Captain_Digital
Maxdsl Yes or No
Thanks for replies
I mainly use internet for email and surfing, but the kids sometimes game online.
Captain_Digital
Maxdsl Yes or No
Can anyone offer any sort of explanation as to the following speed test results from the plusnet speed tester and to why surfing is very erratic and slow!!!Huh
Previous speed test results:
Date Speed Achieved (kbps)
07-02-2007 10:57:52 562.3
07-02-2007 10:54:07 1863.7
07-02-2007 10:48:39 16.6
05-02-2007 10:06:09 1087.8
05-02-2007 10:05:35 1045.6
05-02-2007 10:04:53 1011.6
04-02-2007 18:39:55 478.5
27-01-2007 13:55:10 36.6
27-01-2007 13:46:38 140.3
27-01-2007 13:44:07 125.5
17-11-2006 13:54:01 566.9
17-11-2006 13:53:07 416.8
17-11-2006 13:52:11 944.7
17-11-2006 13:51:52 687.8
17-11-2006 12:18:25 945.3
13-11-2006 14:38:03 1100.6
13-11-2006 14:37:25 1153.3
12-11-2006 00:13:10 913
12-11-2006 00:11:24 1084.5
12-11-2006 00:09:59 1106.9
Thanks for any help
Plusnet Staff
Plusnet Staff
Maxdsl Yes or No
The portal speedtest has been a bit unreliable of late so I'd probably take the results with a pinch of salt. We are planning on replacing it very soon.
I would suggest trying www.speedtest.bbmax.co.uk and see what results that gives.
