MaxDSL sorted for me!!
sophos9
Finally, MaxDSL is working for me, had 2 phonecalls from plusnet today and stable rate has been changed to 8000 and speed test is below
http://www.speedtest.bbmax.co.uk/results.php?t=1147884106&v=47339
This is a great day Cool
Hi.. If you don't mind what product are you on or did you submit a queue jump request.?
cheers fella
sophos9
Was upgraded on the 19th April, no queue jumping or anything
On the premier package, £21.99 per month job....
rz2k7
Blimey that was quick. :shock:
I'm on the same package as you but still waiting to be upgraded.
Been a customer since 2002 and I queue jumped... :?
Sophos,
What was your problem before? Were you (like I still am!) stuck at 2MB downloads?
sophos9
dunno fella?
The problem was a stable 8mb sync with 2mb download, the problem was plusnet not receiving the delta reports from BT however a MSR had been established BT's side
So yep, same problem mate - how long since your upgrade?
Well it's reassuring that it gets fixed eventually!
Two weeks!
Did you do anything at your end to help matters or did just - all at once - the speed start to climb?
sophos9
Hi mate,
12 days should have nailed it for you really, I would submit a support ticket outlining your sync and your MSR and some plusnet & 3 BT speed tests (1 between (midnight and 7am) this would be a real good headstart on the ticket
I had to go through all the hoops such as BT speed tests etc etc but with good reason
You will get sorted soon
Shocked
Thanks Sophos,
I have done all those things already!
So now I just need patience..... :roll:
According to ADSLguide this problem is occuring across all ISPs - so we shouldn't be too harsh on old PN I suppose......
Yeah, I have done all those things already and ticket is still open 3 days later nothing has been done....
sophos9
Cool then you are well on your way then
It seems the problem is with BT sending the delta reports
Must say, when it came to it, Plusnet were very good on the phone so kudos there!
Good luck bro!
Hmmmm, so phoning up and hassling had an effect?
sophos9
Nope, they rang me!!
:shock:
