MaxDSL Activation Dates
Hi, I have been looking at the activation dates for MaxDSL for my home, work and a few friends. We are all with 12 miles and the date on each one is 31/3/06. Does this mean that they are all due to be enabled on the same day or is this date just a rough guide?
Cheers
Hi
going what ive been told all dates are 31/03/06 for all exchanges its just a guide...
The Usertools Exchange checker should provide the information in this format
BT are planning on enabling this exchange for Max DSL products.
Currently, they have given an estimated date of 31/03/06 for this.
Please note: This is the default date from BT and may change
So yes it is an estimate and is not set in stone.
It is hard to know if BT will manage to keep to their schedule but past performance may provide the answer.
thank you, damn I was hoping it would be done by then. I remember when they did the 2mb upgrade and I was one of the last to get it because I am on a small exchange.
Yeh, the majority of exchanges state that date, only a small percentage have been given real estimates. I wouldn't hold your breath and would assume that the 31/03/06 is a pretty meaningless placeholder.
I know exactly how that feels. My home exchange was one of the last In N. Ireland to be enabled. The joys of living in a hamlet.
I cannot see BT being in any rush to sort my exchange tbh. So the 31 march figure for me, i have no doubt will slip. Sad
Plusnet Staff
Plusnet Staff
There's about 170 exchanges I think that have got dates in mid-March, as each set is done we expect to get updates from BT Wholesale which we'll pass on to the Usergroup to update the exchange checker.
They were pretty confident of meeting the dates in most cases, but until a date is confirmed it could slip, as I say as soon as we get that information we will make sure it's made available.
Just wondering when do you plan to put in the order for the free regrades? My exchange has been on MaxDSL since start of January.
They can't do the bulk regrade untill the national rollout is done, so its a case of waiting on BT.
JonathanW
If you're on one of the account types that supports the higher speeds, you should have already been upgraded. On the other hand, if you're still on an Up To 2mb package then there won't be any regrades put through until the product refresh in April.
I wish they hadn't upgrqaded me echange then! the suspense is killing me!
Well you know what to do then, raise to the up to 8Mbps package.
I can't afford it, poor student here!
Any update on the LLU trials? I'm sitting on an easynet LLU'd exchange; on a higher speed compatible product wanting faster speeds!!!
Last I heard there was some problem with easynet not comforming to RADIUS standards or something...
I'm also on an LLU'd exchange (Bulldog and Easynet), it'd be great to hear any progress on the trials.
