MaxDSL ADSL Modem/Router Compatibility
Are there any compatibility issues with MaxDSL and ADSL Modem/Routers? I believe the original standard allowed for 8mbps down and 1mbps up so I assume it shouldn't be a problem. I don't want to miss out because I have the wrong type or router.
Mand
This shouldn't be a problem, unless your kit is ancient!
A quick google search or a look at the manufacturer's website should confirm or deny this though.
I forget to add, it says on the companies site my router will allow up to 8mbps down and 1mbps up. Is there anything else to look out for or is that it? Are there any other standards it has to comply with.
Fixes: 57
This site http://www.faster.bt.com/faqs.asp#modem gives some info on the BTmodems which may be of use
