Max uploads but 2Mb downstream still
I was maxed around 5 days ago and I've seen a big increase in the upstream. For some reason the downstream hasn't change at all. I've rebooted the modem 1 every day but it's still only showing as 2000 in the stable rate.
Here's the modem stats if this helps?
ReceiveAttenuation_dB= 5
ReceiveMargin_dB= 9
RxOutputPower_dBm= 0
SendAttenuation_dB= 2
SendMargin_dB= 25
Strange thing is I get what is perfect for a 2Mb connection at all times, evening in the early hours and peak time.
http://www.adslguide.org.uk/tools/speedchart.asp?id=11473444833287402120
Re: Max uploads but 2Mb downstream still
if you read the sticky at the top of the forum you'll see maxdsl may take 10 days to increase download speed
Mine finally came through in the early hours of this morning - after a full 1 week wait.
