Max Stable Rate stuck at 1500 kps - any suggestions?
Rooster
I've already raised a ticket regarding this (Ticket is 19923568 ) , and was wondering if aynone else had seen this type of problem.
PN have routed ticket to correct team, and whilst I'm waiting for them to reply, I though I'd just check with the community.
I've been a happy MAX DSL user for a couple of months .. speed was variable but download always around 3500 kps.
MSR was shown as 6500, router connected at 4500 - 8192 kps, download around 3000 - 3500.
MSR would vary occassionaly, but a router reboot would kick it back to 6500.
This week has seen MSR stuck at 1500. Re-booted router once or twice a day with no effect.
Here is a history of my speed tests:
27-07-2006 11:10:36 1432.3
27-07-2006 10:40:36 1427.2
27-07-2006 08:22:46 1437.1
16-06-2006 07:00:48 3471.7
15-06-2006 06:12:20 3817.3
31-05-2006 05:17:55 3640.9
28-05-2006 08:39:21 3632.3
Here are some stats from router (bt voyager 2110) which may help...
Line Mode G.DMT Line State Show Time
Latency Type Interleave Line Up Time 00:02:05:58
Line Coding Trellis On Line Up Count 1
Statistics Downstream Upstream
Line Rate 4864 Kbps 448 Kbps
Noise Margin 14.9 dB 22.0 dB
Line Attenuation 30.0 dB 15.5 dB
Output Power 19.8 dBm 12.1 dBm
Any advise / tips gratefully received.
James
Your BRAS was raised to 3424 in the silly hours of this morning. You should see your stable rate lifting shortly, if it has not done so already.
Rooster
Hi James,
Thanks for your speedy reply!
- I'm still seeing MSR 1500. Am I right in remembering the changes take place twice a day 8 am & 8pm? (and I just re-booted my router)
- Is my BRAS variable or set by yourselves? Your reply seems to indicate you can choose what is rather than BT detecting what it should be.
My knowledge may be out of date, so please let me know if my understanding is correct.
Ian.
Rooster
FYI ..
MSR just went from 1500 to 3000.
Speed test show improvement
28-07-2006 13:31:59 2679.1
28-07-2006 13:27:22 1442
28-07-2006 12:54:22 1472.2
James
Good stuff.
