Management levels?
Bernard_Shakey
Management levels?
I've tried to look for all the info pages concerning Management levels and when & why you are placed on them.
I'm on premier 2 on a 2Meg line and have just been put on level 2 management. Here are my month to date stats (billing date is 24th)
Peak usage Off-peak usage Total usage
Peer-to-peer 10.26GB 63.32GB 73.58GB
Other 1.6GB 8.5GB 10.1GB
Total usage so far 12.54GB 72.54GB 85.08GB
I don't feel that i've used enough to be put on level 2 management.
Tell me what I've missed?
Dave...happy with the service...so far...
Management levels?
On Premier 1 - Level 2 Management kicks in at 12.5Gb
Level One = 10Gb
Level Two = 12.5Gb
Level Three = 15Gb
SUP MAX = 30Gb
However as you say you are Premier 2 then you have not used enough as you have only used 12.54Gb.
Check you are on Premier Option 2 and raise a question accordingly.
Bernard_Shakey
Management levels?
yep, def option 2. I chose it for the higher limits (lol) as I did go over on option 1 - or, should I say, its predecessor.
I've raised a ticket but, as it's only a day and a dinner 'till my next billing date, I'm sure they'll screw around and then apologise on the 25th!!
I'd swear, if it didn't get bleeped out.... Evil
