Make webmail advanced settings sticky?
hatchwarren
Every time I log onto webmail I have to change both of the advanced settings, i.e. use the enhanced (IE6) interface and use MAPI(?) as opposed to POP3.
Is it possible to get either PN or IE6 to remember these settings and offer them as defaults next time I log in?
Steve Adams
xon
Good point. I suspect that the probable answer is no, as the Webmail front end would need to be changed in order to select IMAP over POP3 and, inevitably, some customers would probably prefer POP3, although in my experience the IMAP option gives you more control over your email set up than POP3.
However if you are using email client software then you can preselect IMAP and there are setup instructions here:- http://portal.plus.net/support/email/setup/email_setup_guide.shtml
Regards
Andy
Fixes: 8
Surely its just a case of making the login page save a cookie with the last selected settings - not a change to make IMAP or advanced the default which would upset/confuse people.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
/Wonders if Colin is busy yet.... :lol:
James
Perhaps it would be worth raising this in PUGIT for some voting madness.
Laugh
I noticed that once I upgraded to IE7 I used to go in with Advanced E-mail but now I always go in with Simple Mode. Not a big deal from my point of view, but just something I noticed.
