Major connection slow down
MysteryFCM
C'mon PN, whats going on?
Downstream 119 Kbps (14.9 KB/sec) 128 Kbps (inc. overheads)
Upstream 27 Kbps (3.4 KB/sec) 29 Kbps (inc. overheads)
Cleaned and re-started 3 machines to rule out network issues, re-started router, and just a few seconds ago, ran the ADSLGuide speed test, and the above was the results. With the PN speed tester saying;
Your current speed is: 222.00kbps
Which means you can download at 27.75 KB/sec. from our servers.
Exchange status checker thingymibob is showing green for a change, so it's not an exchange problem ....
I realise the connections are contended, and that this is peak time, but this is just silly - especially after the recent "issues" with connections etc that PN seem to have had.
No problems here, speeds normal :?
MysteryFCM
Just to add;
Package: 2MB Premier
Gateway:
You are currently connected to the "Telehouse East, Juniper 3" gateway. This gateway is sometimes known as pte-ag1.
Cajef,
Last year everything was fine, very few issues, and most of them only minor one's. Major issues have only started as of Jan this year ... with the past couple weeks being the worst thus far.
Plusnet Staff
Plusnet Staff
What speed does the BT speedtester show?
http://usertools.plus.net/tutorials/id/27
MysteryFCM
I'm running 3 servers (HTTP, FTP and SMTP) here so haven't actually tried it yet ...
I am aware of the recent problems, but at this time I have no problems.
I am also connected to the same gateway as you.
AG speed test 5 minutes ago.
Downstream 1870 Kbps (233.8 KB/sec) 2019 Kbps (inc. overheads)
Upstream 246 Kbps (30.8 KB/sec) 265 Kbps (inc. overheads)
Edit - Sorry I have just rechecked and am connected to PTE AG2
me too!!
running doggishly slow. unbelieeeevably sloooooow...
2mb premier also..
MysteryFCM
The speed test has completed on test server speedtester1.nat.bt.com for user [REMOVED] and you have downloaded a 1.7Mb file at a speed of
1909 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
Your IP address is 217.47.207.61, your browser is reported as being Microsoft Internet Explorer 6.0 and is running on Windows XP.
Screenshot: http://mysteryfcm.co.uk/misc/imgPN_BTST.gif
@ mysteryfcm
It may help you to know that your link above loaded really slow for me!
Is your site run from your home or hosted by PN?
*EDIT*
BTW I am not suffering any speed issues myself.
shellsong
It just took about a couple of seconds for me.
It could have been down to some of the issues that appear to be effecting certain gateways at the moment (slowdowns, packet loss and laginess on ptn-ag1 and possibly ptn-ag2 especially for certain protocols).
MysteryFCM
@ mysteryfcm
*EDIT*
It's actually partially hosted from home, and partially hosted by FastHosts (the scripts that pull the news and Featured Product, are hosted on my home machine due to restrictions on FastHosts servers).
Ah, ok.
Well I don't know if you have any improvement your end or not, but your graphic just loaded at a normal speed for me just now. (From a cleaned cache).
If you stilI have poor speed, I hope you get sorted soon!
MysteryFCM
It's alot better than it was yesterday, but still not as good as it should be ....
Julie
Things are not good for me either for some reason
speed tests are showing upstram absolutely dire
latest one after many reboots shows the following on a 2MB connection
Downstream 1910 Kbps (238.8 KB/sec) 2062 Kbps (inc. overheads)
Upstream 92 Kbps (11.5 KB/sec) 99 Kbps (inc. overheads)
on Gateway ptn-ag1 as usual
Whats going on..?Huh
