Mailing lists
lingbob
Mailing lists
Greetings All!
What's the difference between setting up a mailing list under "My Circular" and setting one up under "Email Settings".
Regards,
Martin
JonathanW
Mailing lists
My Circular is generally so that you can email a group of people. Where as the mailing list option allows other people to post back to the list, in a more discussion based environment.
lingbob
Mailing lists
OK, thanks for clarifying the difference.
Regards,
Martin
lingbob
Mailing lists
Ooooops, forgot something Smiley
If I set up a mailing list under "Email Settings", how much control would I have over the list, e.g. , would I be able to un-subscribe "undesirable" participants?
Regards,
Martin
JonathanW
Mailing lists
You should be able to unsubscribe them, though it isn't possible to stop them then resubscribing.
The software that's used to run the mailing lists is ezmlm so you should be able to find more information via google.
