Mailboxes & SMTP
Mailboxes & SMTP
Am I correct in assuming that if SMTP is enabled for a domain's email, there is no need to configure mailboxes? (IE all mail to the domain is directed to our server0
thanks
Keith P.
benoh
RE: Mailboxes & SMTP
Yes, thats correct, if you use SMTP mail is delivered direct from the internet to your server, if your disconnected we queue it on our servers until you dequeue it on connection with the finger command.
Ben O'Hara
Network Support Analyst
PlusNet Technologies Ltd.
thanks
K.P.
