Mailbox redirection
Mailbox redirection
Maybe I'm reading things the wrong way - no doubt someone will tell me if I am - but it seems I can only set up a mail redirection from a mailbox I don't have!
It seems a touch illogical to me, but then the whole email system here seems to have a touch of the Heath Robinsons about it ......
Mailbox redirection
Welcome to the forums.
I've often thought that strange. however, it works. To create the redirect, delete the mailbox and then set up the re direct. It wont work while the mailbos exists, as i am sure you have now seen.
Can be a bit confusing.
Mailbox redirection
Yep it is confusing but if you want to redirect from a named box then you have to first delete that box :?
Then you can set up a redirect using the name you have just deleted :? :?
Daft but it works Smiley
Mailbox redirection
we're reading each others minds John. Smiley
Mailbox redirection
Thanks, gentlemen!
