Mailbox password changes: How Long?
I seem to have a continuing problem with this...
The other users of my domain, (i.e. the rest of my family) are always having problems remembering their passwords. (Their fault through lack of use, etc)
Being a good administrator, I frequently set them a new password through the Configure Mailboxes screen.
However, immediately after I've changed the password I find I am unable to login to the mail account on the new password, even using webmail.
I have in the past waited for 24 hours then found access on the new password is OK.
How long should I expect to wait before the new password works?
Is the time for webmail access & POP3 access the same?
(P.S. I've read Ref 40059 - and this may apply to my mailboxes, how do I get my mailboxes checked for this?)
Steve
thehatman
I've had problems with this. In my view it ought to update immediately.
But in fact it takes 24 hours, which is very slow.
Plusnet Staff
Plusnet Staff
Fixes: 159
When you make a change to the mailboxes this causes them to refresh, in effect rebuilding the information. This normally takes 15-20 minutes but can take up to 4 hours.
 Chris Parr
 Plusnet Staff
