Mail Washer
Mail Washer
Sad Has anyone had poblems after they've installed mail washer? Shortly after installation I had continual blue screens of death (only while on-line) and ended up having to re-install windows.
Mail Washer
Been using mailwasher for months now, no problems at all, on both win 98 and XP home.
Mine is the origonal freeware version and not the newer shareware one, so it might make a difference.
Mail Washer
I'm also on the old free one, version 2.0.28, and the only time I've had a problem like that is if I close Mailwasher while it's still doing something. If, for instance, you are checking six accounts and one is not responding, it doesn't like it if you just give up and click the X in the top right to close it - better to hit the stop button (and make sure that it *has* stopped) or wait for the failure message.
Mail Washer
No problems.
It's worked fine for me on Win98se and on XP over the last year or so.
As above make sure you let it complete its mail check(s) before trying to just turn it off as it will complain.
Mail Washer
No problems with that here either.
Been using it for a while without any problems.
