Mac works so why change?
My family use PlusNet account accessible via a 1998 iMac running Mac OS 9.1 via a purchased router. It simply works, and has been reliable for over a year.
We use it for e-mail and some browsing - ie. low usage.
Cuirrent PlusNet account costs about 15 pounds per month.
So.. should I change to a Broadband your way account at approx 10 pounds?
Or am I inviting technical difficulties?
Any advice on above appreciated. THANKS.
Michael
Plusnet Staff
Plusnet Staff
Fixes: 159
The fact that you use a Mac should not have any bearing on which one of our products you are on, as long as your Mac and modem/router continue to work together then you should have no issues connecting to broadband.
 Chris Parr
 Plusnet Staff
Thank you for the reassurance.
Michael
