Mac-compatible wireless router?
Can anyone tell me if the BT Voyager 2110 wireless router offered by F9 is compatible with Mac? I want to set up a wireless network at home for my iMac and Macbook and this looks a good deal if it works...mike
James
All routers should be compatible with Mac's.
It's really only software on USB modems that cause problems. FWIW, my little iBook is very happy with my Netgear DG834Gv2
James, thanks for answering my query. I hadn't realised it was mostly USB hardware that had Mac compatibility problems. This makes my search for a wireless router much simpler. Mike
