MAXDSL - Constant Disconnections
petsyb
Never mind the fact my connection says 7200kbps and it's actually never ran faster than 950kbps and usually is around 500kbps I'm getting constant disconnections every few minutes
when will the the issues of speed and disconnections be fixed ?
Any advice anyone !
how long ago where you upgraded?
Are you using the master socket and have you tried different filters?
It takes something like 10 days for the maximum stable rate to be established.
Remember that much from my time at BT. Hope that helps (*if you've had max less than 10 days, of course)
Don't fool yourself, MaxDSL is just as pants after the 10 days are up.
I'll second that. It's now nearly 11pm and i am still getting speeds of well below 2mb. 1.1mbps on the last test.
Whether this is a BT or Plusnet problem, MaxDSL has been a disater so far for the majority of people.
And during the process of all this.. I actually managed to kill my ADSL router :/
Had the latest firmware upgrade (from 2003 since the product is now discontinued) and basically did well for an hour........ until had MSN connection issues. Then it went.... kapow.
So I reverted back to the old firmware, rebooted. Works nicely. Default setting first... rebooted..... nothing came back. Spent 5 minutes reading the PDF, trawled google for help. Result. Screwed.
I'm going to buy a Netgear ADSL router tomorrow... £70 gone from tomorrow!
