MAC code question
MAC code question
Hi All
If a "MAC code" is requested does that automatically start the migration process: or if need be can it not be used and just left to expire at the end of 30 days?
MAC code question
The migration process is only started when you give your new ISP the MAC code. Otherwise, like you said, it just expires after 30 days and is forgotten about.
Also when you request a MAC, PlusNet's retention team will probably give you a call to try and ..retain you!
MAC code question
Hi Ian,
As I understand it ,if a mac is issued and not used after 30 days, everything remains as is.
MAC code question
Thanks Chris
it was in the back of my mind; that was the situation but just needed clarification.
MAC code question
And Mark
MAC code question
One more thing if I may
What is meant by an "engineer install"? Can an engineer visiting to remove an ISDN Home Highway box and change the phone socket faceplate count as one?
MAC code question
As far as I have seen yes. On the occaisions this has happened for our clients, the isdn has been removed and adsl activated at the same time.
And so far, we havent seen one messed up. Smiley
MAC code question
Not sure if I wrote the question correctly :-( I am wondering about this as I have seen that in somecases having an "engineer intallation' can make migrating problematic.
MAC code question
Ah, yes Ian. I know where you are coming from. I did read recently, maybe on ADSL guide, of this being an issue, at least for one ISP.
Maybe Dave can clear this one up, if he hasnt slipped home yet. Smiley
MAC code question
Thanks once again Mark
