Lycos' MakeLoveNotSpam blocked ?
According to this posting on NetCraft, some Internet Backbones are blocking access to www.MakeLoveNotSpam.com
I think Level3 is a backbone being used by PN, right ?
Any idea if the backbone being used by PN is blocking that site ?
1 REPLY
jberry
We do use use L3 but I am not sure whether they are blocking it or not. I can see why they would do, a DDoS across the atlantic is not something that is going to make their lives any easier - the available bandwidth is already restricted as it costs a lot for fibre under the sea or satelite data.
Regards,
