Loss of connection
waldron
Loss of connection
For about four hours today I was unable get any access to the internet. Last night everything was OK. Today when I powered up at around 11am Internet Explorer and Outlook Express (the two main things I use) would not connect.
I have a D-Link DSL-G640T wireless router (although I am not currently using wireless). The Connection Status said it was Disconnected, and the Connect button had no effect. The DSL speed was 7296 Kbps so I presume I am in the process of being changed to MaxDSL (I think from 9 May). My 'stable rate' is still showing as 2000, and my speed test is usually around 1.9.
MS Messenger troubleshooter failed to find a DNS server.
I consider myself to be a 'novice' user and did not feel confident enough to try changing any settings in the router. So I just rebooted every hour, with the same effect, until around 3:15pm when suddenly everything was OK again.
I cannot find any comments on here about other people having similar problems, and I know that another PN user on the same exchange as me as been connected successfully throughout.
Can anyone offer any advice as to what the problem might be please?
1 REPLY
sisgroup
Loss of connection
I have had the very same issues in the past but mine was for much longer liek 10 hours :? but yes just liek yourself it went without warning and came back just like that :?
