Linux on PlusNet Bit oh Help?
Anyone got it working? i have a speedtouch 330 modem. and is plusNet
pppoa or pppoe?
Thankies Aaron
Best thing I can suggest is do a search on the forums and also on Google for some help.
One thing I can confirm is it should be PPPoA.
Chris
Trying to get a USB based modem working under linux, can be a challenge.
I would suggest getting an ADSL router or Ethernet based modem.
Chilly
I use the Speedtouch 330 USB (the silver one) under FreeBSD thanks to http://speedtouch.sourceforge.net/
Hope that helps!
Diloch,
Andrew D Wiles
See
http://portal.plus.net/central/forums/viewtopic.php?t=34107
It sounds like “smither” has done it.
Chilly
shellsong
Depends what distro you're using how best to do it! Breezy Badger Ubuntu should be ready to go-- earlier versions probably need libatm1 installing. Personally, I don't like USB router/modems
i have some info and i'm not that techy but i can proberly pull it of i was just wondering if there is driver to download. apparently there is and i'm using Fedora Core 4
use gentoo! Smiley
shellsong
Also works fine for me in OpenBSD. In fact I have been using this setup for around four years, originally with the green Alcatel USB and more recently with the Speedtouch 330.
