Linksys ADSL2MUE
Linksys ADSL2MUE
Is anybody else having connections issues with a Linksys ADSL2MUE ?
About 6 weeks ago I was moved to Tiscali circuits and ever since my modem has had problems connecting. I can normally get it going by switching it on, waiting for about 10 minutes as the ADSL light flashes green, turning it off and waiting for a few minuites then turning it back on and waiting another ten minutes then turning it off and waiting and so on until it connects, sometimes after a couple of tries, sometimes after about 10.
I have tried to get f9 to help me resolve the problem - they tested my line and said it was fine, when I told them I was still having problems connecting they tested my line again and said it was fine, then they asked if I was using an extension (I'm not), so now they are testing my line again. They do know what kind of modem I am using, and I would have thought that they would know of any issues with this model - but I get the feeling that none of them have actually read my fault report carefully.
Chris
Plusnet Staff
Plusnet Staff
Linksys ADSL2MUE
Hi Chris,
I can see that the fault has been raised with our suppliers but we don't have any feedback yet.
Can I ask, has any asked you to check your PPP settings to make sure the modem is set on "VC Mux" "VC Encapsulation" rather than "LLC"?
Linksys ADSL2MUE
Thanks for the repsonse,
I already checked that - saw it on a newsgroup somewhere.
Must say that 6 weeks into my difficulties nobody at the support desk has asked me to check my modem settings - I've done some research on the net from work though.
Chris
Linksys ADSL2MUE
I have an ADSL2MUE, and despite being somewhat under-featured, it's worked fine for me at 2meg for a year, so you've probably got a bad unit or a config problem.
