Line Stats
superloon
Line Stats
Can anyone tell me wot speed I will get on MAXdsl. Myline stats are
Attenuation[db] Local 12 Remote 9
SNR Margin [db] Local11.5 Remote13
Cheers :lol:
[Moderator's note by Tom (tomspcs) : Edited title and post to use lower case. Please dont post in all caps as it is hard to read and can cause confusion.]
Line Stats
You can use this little tool to give you an idea posted it cos it might help others
http://www.dslzoneuk.net/maxspeed.php
shellsong
Line Stats
@casa1
There's something screwy about your stats-- attenuation and/or SNR are/is too low!
superloon
Line Stats
can u explain further i thought my stats were good i am only 300 meters from the exchange
cheers Smiley
shellsong
Line Stats
What line sync speed are your stats measured at? If 2Mbps then your SNR is horribly low! See http://www.kitz.co.uk/adsl/linestats.htm
superloon
Line Stats
my sync speed is 2mbps is there any way to get SNR higher
thanks for your help
Line Stats
Hi casa1.
Try this: www.dslzoneuk.net/socket.php
James
superloon
Line Stats
hi again just managed to get phone line in test socket and got new readings so can anyone tell me wot speed on MAX DSL WITH these?
attenuation 10 local remote9
snr 34 local remote 13.5 Cheesy
thank you
Line Stats
casa1
In order to use tht predictor tools you need to input
1. existing connection speed 512, 1024, 2048
2. Local (downstream) Attenuation
3. Local (downstream) SNR
This will give you an estimation of what is likely on your line using the DSLZone tool in the thread.
kjaerligkatt
Line Stats
@casa1
This is indicative of a good signal coming into Linebox, but poor internal wiring introducing high noise levels. I would recommend a thorough review of the internal wiring before MaxDSL goes live, otherwise the line will sync way below its potential.
Regards, Neil
