Limewire connection problems????
Has any of you plusnet users experienced problems connecting to Limewire? Plusnet tell me they do not block P2P networks unless used extensively. If you've had problems and resolved them please let me know how cos i've tried everything apart from throwing PC against a wall x :x x
Try searching for limewire, there are a lot of threads mentioning it which may have a solution.
Also you have posted this in the wrong forum - it should have been community support - a mod will move it when they see it.
Topic moved from Ideas and Suggestions.
