Leaving Plusnet... whats involved
Grimbo
I'be been with Plusnet for almost 8 years, but I'm sadly forced to consider moving (regular loss of email, dodgy Tiscali connection, poor support etc...)
What is the procedure... Is there any downtime, how do you get to keep your Plusnet registered domains, are there any cost implications etc...
Many thanks.
As Lucky Lucky U is involved, atleast 10 daysSad
You can either get an LLU MAC which almost nobody accepts, or do a cease and re-provide, which means at least 7 days downtime.
blowdart
Re: Leaving Plusnet... whats involved
I'd suggest you look at moving your domains to a 3rd party, not your new ISP. This way should you move again you really don't have to worry.
Grimbo
Good call, thanks.
Moderators note by John (johnessex) Full quote of preceding post removed as per the Link:rules
