Latency and speed Issues 06/03/06
Trace route ive just taken, notice the 117ms for the first hop!
1 <1 ms <1 ms <1 ms 192.168.12.11
2 117 ms 106 ms 115 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 98 ms 99 ms 106 ms ge0-0-0-403.pte-gw1.plus.net [84.92.4.1]
4 113 ms 112 ms 111 ms t2a4-ge4-0-1.uk-lon1.eu.bt.net [166.49.211.133]
5 113 ms 112 ms 109 ms t2c2-ge7-3.uk-lon1.eu.bt.net [166.49.135.114]
6 91 ms 90 ms 96 ms t2a1-ge7-1.uk-lon1.eu.bt.net [166.49.135.110]
7 109 ms 110 ms 111 ms 195.66.224.125
8 107 ms 110 ms 109 ms 66.249.87.99
Speed tests are ranging from 26KB/sec to 52KB/sec on a 2mbit connection
Downstream 423 Kbps (52.9 KB/sec) 456 Kbps (inc. overheads)
Upstream 201 Kbps (25.1 KB/sec) 217 Kbps (inc. overheads)
http://www.adslguide.org.uk/tools/speedchart.asp?id=f7df5ecd109d1b7537e9e11c6b1
Im not the only one either , see this thread on AG : http://bbs.adslguide.org.uk/showthreaded.php?Cat=&Board=plusnet&Number=2312261&page=0&view=expanded&...
Rebooted a few times and got on too ptn-ag1 and the letency problem goes away
2 16 ms 18 ms 17 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 18 ms 16 ms 16 ms ge0-0-0-103.ptn-gw2.plus.net [84.92.3.18]
4 16 ms 17 ms 17 ms t2a1-ge5-2.uk-lon1.eu.bt.net [166.49.211.9]
5 18 ms 17 ms 17 ms 195.66.224.125
6 16 ms 17 ms 16 ms 66.249.87.104
speed test come back good now too
http://www.adslguide.org.uk/tools/speedchart.asp?id=d198aead109d1c58009d5b9e4f8
Downstream 1896 Kbps (237.0 KB/sec) 2047 Kbps (inc. overheads)
Upstream 242 Kbps (30.3 KB/sec) 261 Kbps (inc. overheads)
thn-ag1 also appears to be OK at the moment.
To find out what gateway you are on click here.
It Appears theres a problem on pte-ag1 tho? have you noticed it? There are multiple posts regarding this
Moderators note by John (johnessex) BB code enabled in this post to display code and quote correctly
Fixes: 8
I can confirm I'm seeing the same thing:
C:\Documents and Settings\John>tracert ccgi.plus.net
Tracing route to ccgi.plus.net [84.92.1.4]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms dg834 [192.168.0.1]
2 15 ms 13 ms 13 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 15 ms 13 ms 13 ms ge0-0-0-103.ptn-gw1.plus.net [84.92.3.17]
4 16 ms 13 ms 14 ms ccgi.plus.net [84.92.1.4]
Trace complete.
2 16 ms 15 ms 16 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 13 ms 13 ms 15 ms ge0-0-0-103.ptn-gw1.plus.net [84.92.3.17]
4 13 ms 12 ms 12 ms ccgi.plus.net [84.92.1.4]
Trace complete.
Disconnect/reconnect
2 59 ms 57 ms 58 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 54 ms 54 ms 55 ms ge0-0-0-403.pte-gw1.plus.net [84.92.4.1]
4 69 ms 71 ms 71 ms ge0-0-0-22.ptn-gw2.plus.net [212.159.4.2]
5 72 ms 69 ms 66 ms ccgi.plus.net [84.92.1.4]
Trace complete.
2 60 ms 61 ms 61 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 45 ms 43 ms 43 ms ge0-0-0-403.pte-gw1.plus.net [84.92.4.1]
4 47 ms 43 ms 43 ms ge0-0-0-22.ptn-gw2.plus.net [212.159.4.2]
5 40 ms 40 ms 38 ms ccgi.plus.net [84.92.1.4]
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 8
Plusnet - you denied there was a problem with dropped connections for a couple of days - there was.
Please believe us this time - there IS a problem.
cue post about big red font being necessary!!! Cheesy
Agreed. The latency and other issues of the last few days need thorough investigation and the issues resolved. Too much is happening and being reported across the userbase for it to be ignored.
sisgroup
Are you trying to say that there is not enuff support staff in the support centre to cover all the customers support questions :?:
JonathanW
Which is why this was raised through to networks for investigation, I'm fairly sure that I mentioned doing this on Friday evening when this was done.
This is being looked at by networks, though at the moment there is no further information that I have available to share with you.
Fixes: 8
Jon, So why does the latest service status posting about this issue say
Latency Issues - RESOLVED
As per the last update we have identified and resolved an issue that was causing packets to be dropped. Customers should once more be experiencing normal ping times, and anyone still having issues should raise a ticket via contact us.
Please publicly acknowledge the problem by putting out a service status that says that two of the five gateways are at times giving increased latency which may cause problems particularly for gamers and that disconnecting/reconnecting to get a different gateway may improve things.
While you are at it can you why out why @gateway isn't updated to recognise all the gateways - the last I heard was that PUG were waiting for some information or something to be done by Plusnet.
Edit: It looks like this may have been done:
You are currently connected to the "Telehouse North, Juniper 5" gateway. This gateway is sometimes known as thn-ag1.
I had pings of +100ms just getting to portal.plus.net, so I raised a ticket after going through the 'Broadband Fault Checker'.
The ticket was closed by PN stating this could be contention problems at my exchange. Fair enough ... but would rebooting my router an connecting to a different pipe to get lower latency indicate a problem at my exchange? No?
SW.
3Mb FTTC
Unfortunatly it appears the script reading support staff need new updated scripts. That include reconnecting to change pipe to avoid the latency/speed hell that the other pipes are seeing Or perhaps more training?
I think we are all missing the point here. First of all why should we have to disconnect and reconnect to hopefully get on another gateway??. If there is a problem with one of +NETs gateways (which there seems to be and more than 1) then they should fix it. If after several attempts to resolve the offending gateway (which to my knowledge is the case) has failed then they should replace the equipment. It should not be down to the user to keep on rebooting equipment in hope that they get on a better gateway, and at least +net should have standby equipment to put in place so that the offending piece can be taken offline to find out where the fault lies and fix it permanently.
Fixes: 8
A posting from the Usergroup forums here
The network guys have made a few changed on pte-ag1 and pte-ag2 which should improve things. We'll need to monitor for a while to see what happens when it gets busier.
_________________
Regards,
Dave Tomlinson
It will be interesting to see what happens tonight.
