Large number of corrected blocks - is this a problem?
millerabode
Although my router maintains a stable 1Mb connection, it reports a large number of 'corrected' blocks as below
TX Blocks = 41445747
RX Blocks = 41445540
Corrected Blocks = 349347
Uncorrected Blocks = 15870
Never really lokked at this before - does it imply a problem?
1 REPLY
Plusnet Staff
Plusnet Staff
Corrected blocks in itself doesn't imply a problem. It's likely that interleaving is kicking in and doing its job correctly, that is correcting errors in the data.
The line's probably operating at the limits of what it can support and noise spikes are causing errors in the data which the interleaving is there to correct.
