Lag problems
Lag problems
Any one having lag issues playing any multiplayer games or is it just me ?
James
Lag problems
What kind of ping response to you get when pinging the server directly from a command prompt on your machine?
Lag problems
We'll I dont know how to do that, but when im at server lists my ping is 500+ on uk servers, Can't even connect at that. Been like this for weeks now.
thanks for fast reply.
James
Lag problems
Click on start, click on run.
Type cmd hit enter
type ping "server ip address"
Lag problems
Heres a screen shot i took might help
http://img294.imageshack.us/img294/5451/untitledae6.jpg
U can see the bad pings I get ...
James
Lag problems
I'm also unable to hit that IP address. Trace routes and nslookups seem to be suggesting that the problem is at their end rather than ours.
Lag problems
Have any suggestions to help me get my speed back to normal ?
James
Lag problems
Have you tried any alternate servers?
Lag problems
I've tryed loads of servers, still high pink rates can't even play any MMORPG's online what i am paying for.
Heres a list of some more servers
84.98.84.17
84.19.188.153
84.244.170.31
84.244.166.134
Its weird i can browse the web ok ish! but when playing games its a no go >>>
James
Lag problems
Okay, are you able to ping *any* of those servers? They all look like similar IP addresses, possibly suggesting that the same issue may apply.
Lag problems
Yeah I can ping them they come up with 45ms 'Ping' but once connected 500+. This problem must be with Tiscali ?
James
Lag problems
Not necessarily. Can you supply me with traceroutes for each of those ip addresses? To do a trace route, you do the same as a ping but use the command "tracert ipaddresses" instead.
Also, what kind of http speeds do you get Here
Lag problems
When i try tracert ipaddresses it says 'Unable to resolve target system name ipadress'
download 1920 kbps
upload 236 kbps
James
Lag problems
Sorry, I meant that you actually had to enter the IP address of the server rather than the word 'ipaddress'.
Lag problems
Hehe i did Tongue Still cudn't resolve system
Thanks for the help so far appreciate it.
did it getting request timed out. Ill post a SS
http://img242.imageshack.us/img242/1787/121ij7.jpg
