LLU gateway switch
dannykos
LLU gateway switch
just wondering if the LLU router switch was complete yet? I'm now showing as connected to the "unknown" gateway!!
anyhow - is this supposed to be faster / more reliable?
LLU gateway switch
All LLU users have been moved over.
It is not intended to be any faster, in fact its performance is exactly the same as the old kit but has more redundancy/resilience built in so can cope with a major hardware failure much better.
Your speed is governed by the connection to the exchange, local exchange contension, the BT central contention and traffic shaping, not the gateway kit.
LLU gateway switch
I'm also on gateway unknown. Did the gateway checker tell you about juniper 3 as well.
I'm not on llu. I opted out and tiscallis not at my excange
Which gateway
You are currently connected to the "unknown" gateway. This gateway is sometimes known as pth-ag1.
Note: At the moment this could mean that you are on the "Telehouse East, Juniper 3" gateway.
Could it be we're just on the same constipated gateway, my speeds are horrendous but bt says I'm getting 5000 plus.
A
LLU gateway switch
The gateway checker knows about thn-ag2, the new LLU gateway.
I'll pass on your result and get it corrected. I thought it did know about pth-ag1.
James
LLU gateway switch
I think it's giving off dodgy information.
You should be on thn-ag2.
LLU gateway switch
Are you sure James, amcclean says he is not on LLU so why should they be on thn-ag2.
James
LLU gateway switch
Sorry, my mistake.
I'm not aware of a gateway called pth-ag1. Will look into this for you.
James
LLU gateway switch
amcclean,
Could you possibly supply a traceroute?
James
LLU gateway switch
Have definitely confirmed that there is no such gateway.
Will speak with Colin and ask him to have a look.
LLU gateway switch
I'll need to see tracert to do anything about it. Apparently there must have been a pth-ag1 at some point, otherwise I wouldn't have a bit in the code to say 'This gateway is sometimes known as pth-ag1'. In fact, according to the code, pth-ag1 comes straight out of the tracert from the server.
Fixes: 8
LLU gateway switch
pth-ag1 was a Redback
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
James
LLU gateway switch
That must go back quite a bit? I'm sure it's before my time at least Smiley
Fixes: 8
LLU gateway switch
The fount of all knowledge
The last update Kitz had was that they were being deployed as backup devices. I was wondering if they'd been pressed in to service to alleviate the sessions problem.
James
LLU gateway switch
Definitely nothing that's been communicated to me and I would be extremely surprised if this had happened, given all the talks that we've been having about the Firewall implementation et al.
Fixes: 8
LLU gateway switch
I'd love to know why people suddenly saw that ghost from the past!
