LLU connection drops since Friday pm
churtonst31
I've been suffering connection drops on my LLU connection since Friday PM - it is normally perfectly stable.
Any known faults? Is this a wider problem?
Simon
I'm not aware of any at the moment - not general ones anyway.
What do you mean by 'drops'? Does it loose LCP/PPP connection but remains in sync or looses sync completely?
What router do you have and what are the line stats. Have you noticed the stats change at the time the connection drops.
churtonst31
Peter, thanks for replying.
As far as I can see I maintain sync but lose PPP connectivity.
I run a Zyxel Prestige 2602 HWL and the line stats are good:
Upstream Speed: 579 kbps
Downstream Speed: 7981 kbps
noise margin upstream: 12 db
output power downstream: 22 db
attenuation upstream: 19 db
noise margin downstream: 2 db
output power upstream: 12 db
attenuation downstream: 36 db
I'm not very good at reading my logs yet - so I don't know what the relevant error message is.
I noticed this topic and think they are probably related:
https://portal.plus.net/central/forums/viewtopic.php?t=50701
