LCP Drops
LCP Drops
is anyne else experiencing drops in LCP at all. My connection stays in sync most of the time, the router resyncs of its own mind probably once or twice every other day, prob due to SNR issues, sync rate dosnt really change though. However when looking at the logs, I see a good few episodes of LCP Down, LCP allowed to come up, the CHAP authenticatin success, very occ I get CHAP authentication failures. Anyone any idea why this is. I am on Max not LLU (moved back to max). Plus dont seem to have any idea, and say my line is fine, which I agree with, as BT have been out to fix a voice fault recently, and replaced the line from the pole to the exchange for me. Is this due to the normal timeout or anything else?? The LCP down issues appear to be random, the router can be up for hours at a time sometimes, then occ for just a couple, then LCP down again.
1 REPLY
BigDaz
LCP Drops
Yes, occasionally. I'm on max, not LLU.
Usually I can switch my router off, wait 20 mins or so and then try again and it works.
