Keep getting Disconnected
I log on to plus net then a few minutes later I get cut off why is this.
Doreen
1 REPLY
RE: Keep getting Disconnected
You shouldn't be getting disconnected once you have connected - but if you are it could be caused by
1) Line noise
2) Faulty Modem
3) Auto-Disconnect set on your machine
To ensure it's not auto-disconnect, check your internet settings. If this is not set, contact BT on 150 and ask them to increase the gain on your phone line.
Regards,
Mike
| Mike Grice....................Unmetered & ADSL solutions
| Technical Support.....................for Home & Business
| PlusNet Technologies Ltd.........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
