Just got my 2meg connection
It says in the e-mail I got that I have to restart my router (BT Voyager 2100). I'm pretty sure I did this OK. How do I find out what speed I'm running at? i've opened network connections and gone to the LAN settings and it says the speed is 100 Mbps. Is this right or have I done something wrong?
My hunch is that thats the speed between your pc and router. (definalty not the speed between you and plusnet).
Run the speedtest on this site to see how fast your connection is and post back.
I'm getting around 1.8 mbps
I'm getting 960kbps Sad
reset my modem router and ran a bandwidth test... why isnt mine as big as yours? :-o
I guess that means mine has upgraded OK. What speed should I be downloading at?
That sounds right. I normally get between 1.7 and 1.9 on a 2meg connection. All looks good!
M
genetics? :-)
Got mine... AT LAST¬!!! :?
nicandpaul: your line's only been upgraded to 1Mb, I'm guessing. That's probably due to the length of your telephone line (distance to the exchange).
Check your line figures - if they're borderline for 2Mb you may be able to ask PN to request a manual regrade, but that could make your line unstable.
