Just Tooooo Slloooowwww
This is getting rediculus <sorry about my poor spelling..>
Just started to d/l some liunx software from a dedicated server and my d/l speeds are between 20 - 70kbs, so got my son on his pc upstairs to try d/l on his BB premiuer connection and his connection is the same,
Gave my friend a buzz just up the street asked him to try the d/l and hes maxing out at over 230kbs only diffrence hes with a different ISP..
this is gone beyound a joke now Plusnet the sooner i get my MAC key the better,
:twisted:
LiamM
Care to give me a link and I'll investigate?
@martinfamily
thxs for reply heres the link
http://www.linuxiso.org/distro.php?distro=17
11:05 are speeds have moved up too 120kbs un still going up 160kbs now,
Best ive had tonight so far, :roll:
i am getting 226-228 my norm is 234 268 some times WOHO!
yup the speeds have been truly awful, i have raised a second ticket over this. will be moving from this shoddy p.o.s isp after my contract.
"have you done the bt speed tests?"
don't dare come to us with that crap. bt speed tests are always fine. its the isp. it stinks.
if the bt tests are fine why not tell them that instead of ranting?
if they take this information and ask you again without referring to it then by all means go ballistic.
i told them, but they wernt having any of it.
they asked for you to perform tests, you provided the information and they weren't having any of it?
do i understand the sequence of events correctly?
basically i did alot of bw tests and i was told to do more. not acceptable behavour.
Sorry Justin but couldn't resist.
"Children this is unacceptable behaviour"
This seems a bit of a recurring theme, maybe plus should give their agents some additional training on the subject.
