Just Double Checking
Did I read correctly;that to access my account via other phone numbers with the CLI's registered I need to set up a fixed IP? Also although I had a fixed IP a few years back with another ISP with no apparent problems I am wondering if there are any particular security issues with a fixed IP.
RE: Just Double Checking
Hi there Ian,
The Fixed IP will be set up automatically when you register more than one IP address. Generally, having a fixed IP is nothing to worry about, if you run a firewall (which we suggest everyone does anyway).
Regards,
Mike
| Mike Grice Unmetered & ADSL solutions
| Technical Support for Home & Business
| PlusNet Technologies Ltd. @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
> Hi there Ian,
> Regards,
> Mike
Thanks Mike,the reply was appreciated
